If you are having problems with Zabbix crashing under windows check your diskperf setting.
It probably has been mentioned here before because it was so obvious but just in case, make sure you have LogicalDisk's enabled before you try and monitor them
Standard zabbix disk space items appear OK with or without.
run "diskperf" from command prompt, then if you need to enable Logical Performance counters, run "diskperf -YV".
This fixed most of my problems (where it crashes shortly after starting), but there does still seem some other issues with random crashing. Has anyone created a helper script to restart after a crash?
Standard zabbix disk space items appear OK with or without.run "diskperf" from command prompt, then if you need to enable Logical Performance counters, run "diskperf -YV".
