vfs.fs.size[<dir>,used] always return same incorrect value.
As you can see i alway get the same vale, excet a few bytes. In a subfolder of /home there are over 9.5GB of data but if i want to check this folder (/home/abc/def/_streamrecords) i also get same value as shown above.
-Greetz
MAD
madx:~# zabbix_get -s radio-***.de -p 10050 -k vfs.fs.size[/etc,used]
207932032
madx:~# zabbix_get -s radio-***.de -p 10050 -k vfs.fs.size[/usr,used]
207932052
madx:~# zabbix_get -s radio-***.de -p 10050 -k vfs.fs.size[/var,used]
207932052
madx:~# zabbix_get -s radio-***.de -p 10050 -k vfs.fs.size[/home,used]
207932056
207932032
207932052
207932052
207932056
-Greetz
MAD
is there any way to monitor the size of a directory then?
