Feature Request: Macros in triggers names
  • rvillaca
    • Sep 2005
    • 33
    Hi all,
    I have sucessfully created the following macro in actions:
    {{HOSTNAME}:{TRIGGER.KEY}.last(0)}
    But, when I try to use that on a trigger name it does'n work. I thought it will work because of the {HOSTNAME} macro that i use in every trigger.
    I think its a very useful macro. For example, you can setup a trigger for monitoring the CPU usage and alert if you have more than 70% used, than you add that host to a map and you can see a message like "host01 - CPU Util 90%".
    Anyway, I think that the same macros avaliable for actions should be availiable for the triggers title and comments.
    Thanks for building a great NMS,
    Rodrigo
  • mary nancy
    • Jul 2005
    • 125
    Hi
    I alsp badly need solution to the same problem wherein i want the valure of the trigger. I used the Macro TRIGGER.KEY it is not working.
    Somebody please point solution.....
    Thanking you
    Regards
    Nancy
