Cannot create graphs or maps in 1.1beta6
  • llama
    • Mar 2005
    • 13
    #16
    Maps not working
    I am using Mandrake 10.1 for an OS
    tried both 1.1alpha7 and 1.1beta9
    graphs work pefectly which means my php-gd install is fine??
    but MAPS do not work on either of these versions.
    In alpha7 the map grid picture showed up until I add a item to the map, then i get a picture place holder in place of the map grid picture that was previously there.
    In beta9 as soon as I attempt to add an item it simply does not add it, and i can no longer modify that MAP.
    Both versions put this in /var/log/http/error_log:
    Segmentation fault (11)
    everytime you attempt to view the map.
    need help! I love zabbix, but the main reason i use it is for MAP.
    • llama
      • Mar 2005
      • 13
      #17
      # rpm -qa |grep gd
      libgd2-devel-2.0.27-3.2.101mdk
      libgd2-static-devel-2.0.27-3.2.101mdk
      php-gd-4.3.8-2mdk
      libgd2-2.0.27-3.2.101mdk
      Am I missing a gd RPM?
      • llama
        • Mar 2005
        • 13
        #18
        No one has any ideas?
