Maps not working
I am using Mandrake 10.1 for an OS
tried both 1.1alpha7 and 1.1beta9
graphs work pefectly which means my php-gd install is fine??
but MAPS do not work on either of these versions.
In alpha7 the map grid picture showed up until I add a item to the map, then i get a picture place holder in place of the map grid picture that was previously there.
In beta9 as soon as I attempt to add an item it simply does not add it, and i can no longer modify that MAP.
Both versions put this in /var/log/http/error_log:
Segmentation fault (11)
everytime you attempt to view the map.
need help! I love zabbix, but the main reason i use it is for MAP.
