Triggers in beta7
  • navtek007
    • May 2005
    • 100
    Triggers in beta7
    A couple of questions about triggers in beta 7:
    1. Can triggers still be linked in the following way
    Exchange -> HOST1
    Windows.Base -> HOST1
    OR from a couple of post that i've seen has all this changed to the following
    Exchange -> Windows.Base -> HOST1
    SQL Server -> Windows.Base -> HOST2
    Have I got this correct? If so what happens if I want a windows.base template for all my windows servers then that means that in this scenario that all my hosts would receive all exchange and sql server items/triggers/graphs even if they are not an exchange server? To me this doesnt sound too practical and for this reason it would probably stop me from going to beta7.
    2. If I do go to beta7 from beta6 would all my current triggers be deleted?
    Thanks.
  • bbrendon
    • Sep 2005
    • 873
    1. your second guess is correct. there is a problem with this as you've already described. obviously you can have multiple templates, but i agree, it isn't a great solution. i wasn't sold on templates in beta6 either.
    2. no, triggers are not deleted.
    you should backup your database before upgrading, like a good sysadmin does
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • rickardp
      • Dec 2004
      • 27
      Templates
      We have been running zabbix for a looong time. We have gotten to the point where we have to spend much time on adding triggers and items manually on every host since templating haven't worked properly in previous versions.
      Now it's time to scrap 5 years of db config and make REAL templates.
      After 2 days of tedious template items and trigger copy and pasting im getting there.
      I thought along the line of Connecting the host to the application and THEN to the host arch specific templates.
      HOST1 -> Exchange -> Windows.Base
      HOST2 -> SQL Server -> Windows.Base
      HOST3 -> Windows.Base
      Best regards to you zabbix users
      • elkor
        • Jul 2005
        • 299
        yeah, what rick said
        • navtek007
          • May 2005
          • 100
          Thanks, i didnt think of reversing the templating order.
