Grahing problem in 1.1beta7
  • jono
    • Mar 2006
    Hi All,
    First of all thanks for ZABBIX; great bit of software....
    Im having problems with the graphing. All the graphs that are for periods
    shorter than 24 hours are shown as broken images. 24 hours and above work
    great.
    Ive checked GD and all seems fine and the maps display properly.
    Anyone else experiencing this and if so is there a work around?
    Cheers
    jono
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Perhaps DB schema does not match frontend, i.e. using old schema for the latest frontend.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • jono
      • Mar 2006
      Graphing
      Thanks for that. How do I get hold of the newest schema?
      jono
      • ian_d
        • Sep 2005
        • 11
        Hi Jono,
        Updating the schma is part of the upgrade process. Please refer to the documentation about upgranding. Instrucions are there and are pretty straightforward.
        Good luck
        Ian
        • jono
          • Mar 2006
          wasnt an upgrade...
          ...Installed from scratch!
          jono
          • fdiaztrias
            • Nov 2004
            • 9
            Hi all,
            I upgraded from alpha7 to beta7 (using the same procedure as allways) and I have the same problem. I can't see graphs under aweek of length.
            How can I roll back to the old (beta6) DB schema ?
            Thanks a lot
            Franc
