Hi there!
I got Zabbix running with several hosts, 1 template-host, and some triggers. The monitoring works perfect, although the messaging does not work.
The error-log states:
023854:20060310:115510 Expression [({11292})=0] cannot be evaluated [Unable to get value for functionid [11292]]
023854:20060310:115510 Evaluation of expression [({11298})=0] failed [Unable to get value for functionid [11298]]
023854:20060310:115510 Expression [({11298})=0] cannot be evaluated [Unable to get value for functionid [11298]]
023854:20060310:115510 Evaluation of expression [({11287})=0] failed [Unable to get value for functionid [11287]]
023854:20060310:115510 Expression [({11287})=0] cannot be evaluated [Unable to get value for functionid [11287]]
023854:20060310:115510 Evaluation of expression [({11293})=0] failed [Unable to get value for functionid [11293]]
023854:20060310:115510 Expression [({11293})=0] cannot be evaluated [Unable to get value for functionid [11293]]
023854:20060310:115510 Evaluation of expression [({11299})=0] failed [Unable to get value for functionid [11299]]
023854:20060310:115510 Expression [({11299})=0] cannot be evaluated [Unable to get value for functionid [11299]]
023854:20060310:115510 Evaluation of expression [({11305})=0] failed [Unable to get value for functionid [11305]]
023854:20060310:115510 Expression [({11305})=0] cannot be evaluated [Unable to get value for functionid [11305]]
023854:20060310:115510 Evaluation of expression [({11294})=0] failed [Unable to get value for functionid [11294]]
023854:20060310:115510 Expression [({11294})=0] cannot be evaluated [Unable to get value for functionid [11294]]
023854:20060310:115515 Evaluation of expression [({11300})=0] failed [Unable to get value for functionid [11300]]
023854:20060310:115515 Expression [({11300})=0] cannot be evaluated [Unable to get value for functionid [11300]]
023854:20060310:115515 Evaluation of expression [({11306})=0] failed [Unable to get value for functionid [11306]]
023854:20060310:115515 Expression [({11306})=0] cannot be evaluated [Unable to get value for functionid [11306]]
023854:20060310:115515 Evaluation of expression [({11273})=0] failed [Unable to get value for functionid [11273]]
023854:20060310:115515 Expression [({11273})=0] cannot be evaluated [Unable to get value for functionid [11273]]
023854:20060310:115515 Evaluation of expression [({11295})=0] failed [Unable to get value for functionid [11295]]
023854:20060310:115515 Expression [({11295})=0] cannot be evaluated [Unable to get value for functionid [11295]]
023854:20060310:115515 Evaluation of expression [({11301})=0] failed [Unable to get value for functionid [11301]]
023854:20060310:115515 Expression [({11301})=0] cannot be evaluated [Unable to get value for functionid [11301]]
023854:20060310:115515 Evaluation of expression [({11307})=0] failed [Unable to get value for functionid [11307]]
023854:20060310:115515 Expression [({11307})=0] cannot be evaluated [Unable to get value for functionid [11307]]
023854:20060310:115515 Evaluation of expression [({11274})=0] failed [Unable to get value for functionid [11274]]
023854:20060310:115515 Expression [({11274})=0] cannot be evaluated [Unable to get value for functionid [11274]]
If I delete all triggers from the template, and create them manually on the host, the triggers seem to work. Is this a bug that I can't find, or what?
Data:
Host template:
tpl_lb
Linked host:
/tpl_Lb/1060
IP: 213.193.214.152
Linked with Template: tpl_lb
Has Group: Lb
Item for 1060:
tpl_Lb:FTP (and more)
Trigger for 1060:
tpl_Lb:FTP Down ( ({1060:ftp.max(300)})=0 )
Action:
Host group = "group_lb"
Send message to: Usergroup Lb.
Data:
Host template:
tpl_lb
Linked host:
/tpl_Lb/1060
IP: 213.193.214.152
Has Group: Lb
Item for 1060:
Trigger for 1060:
Action:
