bulkloader broken in beta 7
  • haxor
    • Jul 2005
    • 11
    I posted this in the troubleshooting thread, but since I can't seem to get a reply, I will try here.
    When I try to use the bulkloader in beta 7 I get a warning, then it adds my first host, then I get an error and it stops. No more hosts are added.
    Here is the warning:
    Warning: Invalid argument supplied for foreach() in /var/www/localhost/htdocs/zabbix/include/hosts.inc.php on line 85
    Here is the error:
    Fatal Error: Call to undefined function: add_template_linkage() in /var/www/localhost/htdocs/zabbix/bulkloader.php on line 114
    I grepped in the php and there is no function add_template_linkage(). Did someone forget to write it or include it with the distribution?
  • bytesize
    • Aug 2005
    • 71
    I can confirm the exact same issue. I have tried with several .csv's which worked fine in beta6 but no joy.
    John
    • krusty
      • Oct 2005
      • 222
      Hi i found out that different function are lost in version 1.1beta7, so the bulkloader couldn“t work fine. I think and hope this will be fixed in 1.1beta8.
