Error in API host.create()
  • phl4kx
    • May 2010
    Hi friends, Im using Zabbix 1.9.8 download from zabbix web page, Im developed my own API frontend, all other calls to API are ok but I have this error when I use host.create() method:
    Array ( [jsonrpc] => 2.0 [error] => Array ( [code] => -32500 [message] => Application error. [data] => No permissions to referred object or it does not exist! ) [id] => 20
    I can create hostgroups but I cant create Host, Im using Admin user
    here is the PHP code:
    PHP Code:
    //CREAR HOST
    $host = Windows001;
    $data = array (
    'jsonrpc' => '2.0',
    'method' => 'host.create',
    'params' => array ('host' => $host,'interfaces' => array ('type' => 1,'useip' => 1, 'ip' => '192.168.3.1', 'port' => 10050, 'status' => 1),'groups' => array ('groupid' => 40),'templates' => array ('templateid' => 10002)),
    'auth' => $auth,
    'id' => 20
    $data = consultar_zabbix($data);
    print_r($data)."<br>";
    please some help, thanks
  • marcherren
    • Mar 2011
    • 28
    Facing the same problem, have you found a solution to it?
    • LeoCombes
      • Mar 2011
      • 32
      same for me...
      • marcherren
        • Mar 2011
        • 28
        Have a look at ZBX-5209
