Warning. Field [selementid1] is mandatory
  • woger
    • Sep 2005
    • 56
    Hi there,
    I just upgraded from 1.1beta2 to 1.1beta8 and everything seemed to work out great. I had some problems with graphs not showing, but that was the "memory_limit = 8M" in the php.ini. (PHP Fatal error: Allowed memory size of 8388608 bytes exhausted in apache log). I can add items to a map but when I try to create a connector between 2 items I get these errors:
    Warning. Field [drawtype_off] is mandatory
    Warning. Field [color_off] is mandatory
    These fields are filled in, so that's not the problem.
    I also missed a 1.1beta3_to_1.1beta4 map in the upgrades/dbpatches dirs. Is that because there were none?
    Roger
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Yes, some version upgrades does not require patches, that's why there are missing directories in upgrades/dbpatches.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • woger
      • Sep 2005
      • 56
      Yes, I thought it was that.
      Any idea why I get the errors in maps?
      Thanks,
      Roger
      • Niven
        • Apr 2005
        • 20
        I'm also getting these warnings after upgrading to beta8 from beta7
        • adam.vollrath
          • Apr 2006
          • 31
          I've submitted a patch for this:
