2.0.0rc1 Proxy Not Starting CentOS 6 on AWS Server
  • mvchris
    • Mar 2012
    Hi Zabbix Community,
    Proxy is not starting properly on CentOS 6 in AWS Server.
    I have this set up with 2.0.0rc1:
    Zabbix Server + Agent - CentOS5, no problem.
    Zabbix Proxy + Agent - CentOS5, no problem
    Zabbix Agent - CentOS 6, no problem. But on the same box the zabbix_proxy seems to fail starting all the processes it needs to run and doesn't communicate back to the server.
    Would this be a CentOS 6 problem, or an AWS hosting problem?
    The ./configure settings were the same for proxy on CentOS 5 and CentOS 6:
    ./configure --enable-agent --enable-proxy --with-net-snmp --with-libcurl --with-sqlite3 --prefix=/opt/zabbix
    I can give more details if you require.
    Cheers
    Chris
  • mvchris
    • Mar 2012
    [solved]
    It was a configuration file error.
    I just copied a new config and tested it and it worked (started the processes).
    Made my changes carefully and when I was done it started up properly.
