2.0.0.rc2 Frontend problems with menus
  • miquel.gonzalez
    • Mar 2011
    Hi!
    After having used zabbix 1.8.4, I have recently installed zabbix 2.0.0rc2 and giving it a try.
    It seems that monitoring is OK, but I have found some little problems in the web interface:
    Sometimes when clicking into a menu, the content is not displayed, and have to reload the page or click it 1 or 2 times...
    Or sometimes some of the dashboard panels is showing nothing, or "loading", similar to other post "dashboard doesn't look good within Android's standard browser".
    Some examples:
    I have tried with Chrome 17 and Firefox 10.0.2 with the same results. The installation is like this:
    - Fedora Core 9 over Oracle VirtualBox
    - Apache 2.4.1 + php 5.4.0
    Any idea?, Do you know if it can be because of the beta version, or because my installation?
    Thanks in advance!
    Miquel González
  • zalex_ua
    • Oct 2009
    • 1286
    I suppose something wrong at your side. Maybe some performance issue.
    All is fine for me, I'm using trunk long time already.
    • miquel.gonzalez
      • Mar 2011
      Thank you for the response!
      It was a problem with my installation, finally I placed a new zabbix on a physical machine and the strange behavior dissappeared...
