1.1Beta8 Userparameter that return negative value
  • Wolfgang
    • Apr 2005
    • 116
    Using: Zabbix version 1.1beta8.
    i tried returning a negative value from a userparameter using type float in the webinterface.
    the script used for testing the userparameter is very simple:
    #!/bin/sh
    echo "-10"
    This leads to unsupported.
    "Type of received value [-10] is not sutable for [test.status@woltest]"
    However this one works:
    #!/bin/sh
    echo "10"
    And also this one is ok:
    #!/bin/sh
    echo "0"
    Does the agent not support negative return values when using type float in the webinterface?
    Because the values i need to collect are numeric, i would not want to use type character.
    Wolfgang
    http://www.intellitrend.de
    Specialised in monitoring large environments and Zabbix API programming.
