DisableActive=1 became unsupported
  • frater
    • Oct 2010
    • 340
    After upgrading from rc2 to trunk, my zabbix agent didn't start anymore.
    It turned out I had to remove "DisableActive=1" from my /etc/zabbix/zabbix_agentd.conf
    Why is this?
    HTML Code:
    # /usr/local/sbin/zabbix_agentd
    zabbix_agentd [11363]: unknown parameter [DisableActive] in config file [/etc/zabbix/zabbix_agentd.conf], line 47
    Nothing showed in the log, BTW.
    Did see this:
    Zabbix 2.0.0rc3 (revision {ZABBIX_REVISION})
    What should I do to let it show the revision?
    Zabbix agents on Linux, FreeBSD, Windows, AVM-Fritz!box, DD-WRT and QNAP
  • richlv
    • Oct 2005
    • 3112
    http://www.zabbix.com/documentation/..._configuration
    http://www.zabbix.com/documentation/...tes_for_agents
    as for revision, you probably will need to do make dist from an svn checkout or something similar
