Format of System Uptime using Linux and Windows
  • Wolfgang
    • Apr 2005
    • 116
    using beta8:
    Uptime Item using win32 agent requires: system[uptime] and outputs (using unit = s):
    2d4h36m8.46282799999s
    Item using linux agent requires system.uptime and outputs (using unit = s):
    17d2h5m44s
    The "problem": Using the new vertical Hostnames, the enite colum is set to the width of the output of uptime, which looks not so good for the win32 agent.
    Also, it would be great to allow for just day/hour or mon/day etc.
    Anyway, thanks for this great software!
    Wolfgang
    P.S. Also, it would be great, if the win32 agent would follow the same item names as the newer linux version does.
    http://www.intellitrend.de
    Specialised in monitoring large environments and Zabbix API programming.
