Expressions in 1.1b9 not working correctly
  • bdub
    • Apr 2006
    • 24
    I'm not sure if this is my fault or a bug, either way, I'm on a looming deadline to get this working, so any help would be appreciated.
    I'm attempting the following trigger:
    {testbed:mysql[ping].max(300)}=1
    The graph for this trigger is constantly showing [No Data]
    My agentd.conf file looks like this:
    Server=10.5.5.10
    # Server port for sending active checks
    ServerPort=10051
    Hostname=dingey
    ListenPort=10050
    #ListenIP=127.0.0.1
    StartAgents=5
    # How often refresh list of active checks. 2 minutes by default.
    #RefreshActiveChecks=120
    #DisableActive=1
    #EnableRemoteCommands=1
    DebugLevel=4
    PidFile=/var/tmp/zabbix_agentd.pid
    LogFile=/tmp/zabbix_agentd.log
    Timeout=3
    UserParameter=mysql.ping,mysqladmin -uroot -p <password> ping|grep alive|wc -l
    My agentd.log looks OK:
    002558:20060502:102011 Before read
    002558:20060502:102011 In delete_all_metrics()
    002558:20060502:102011 Parsed [ZBX_EOF]
    002558:20060502:102011 Sleeping for 60 seconds
    002558:20060502:102111 Sleeping for 60 seconds
    002558:20060502:102211 In refresh_metrics()
    002558:20060502:102211 get_active_checks: host[10.5.5.10] port[10051]
    002558:20060502:102211 Sending [ZBX_GET_ACTIVE_CHECKS
    dingey
    002558:20060502:102211 Before read
    002558:20060502:102211 In delete_all_metrics()
    002558:20060502:102211 Parsed [ZBX_EOF]
    002558:20060502:102211 Sleeping for 60 seconds
    But my server log is showing the following errors:
    004050:20060502:095848 Expression [{11256}=0] cannot be evaluated [Unable to get value for functionid [11256]]
    004053:20060502:095900 Evaluation of expression [{11237}=0] failed [Unable to get value for functionid [11237]]
    004053:20060502:095900 Expression [{11237}=0] cannot be evaluated [Unable to get value for functionid [11237]]
    004053:20060502:095901 Evaluation of expression [{11238}=0] failed [Unable to get value for functionid [11238]]
    004053:20060502:095901 Expression [{11238}=0] cannot be evaluated [Unable to get value for functionid [11238]]
    004053:20060502:095930 Evaluation of expression [{11237}=0] failed [Unable to get value for functionid [11237]]
    004053:20060502:095930 Expression [{11237}=0] cannot be evaluated [Unable to get value for functionid [11237]]
    004053:20060502:095930 Evaluation of expression [{11238}=0] failed [Unable to get value for functionid [11238]]
    004053:20060502:095930 Expression [{11238}=0] cannot be evaluated [Unable to get value for functionid [11238]]
    If anyone has any ideas of where else I can look, something else I could troubleshoot, or any other ideas as to what could be wrong, I'd GREATLY appreciate any help you can provide.
    Thanks much!
    brian
  • krusty
    • Oct 2005
    • 222
    It´s only an idea.
    I use in zabbix_agentd.conf this
    UserParameter=mysql.ping,mysqladmin -uroot -p<password> ping|grep alive|wc -l
    This works for me. (use -p without space character).
    Perhaps this was the fault
    • nikoula
      • Jul 2005
      • 29
      re : Expressions in 1.1b9 not working correctly
      If you look carefully at the UserParameter and the item you can find that thay're different.
      Userparam : mysql.ping
      Item : mysql[ping]
      I've the same problem and i've change my item key to "mysql.ping", everything goes fine now for this point
      • bdub
        • Apr 2006
        • 24
        Item : mysql[ping]
        I did that, and still no dice.
        It´s only an idea.
        Actually, since I'm troubleshooting this issue, I've removed the password from the database. So, from the command line, the parameter works
        brian@testbed:/tmp$ mysqladmin -u root ping
        mysqld is alive
        brian@testbed:/tmp$ mysqladmin -uroot ping|grep alive|wc -l
        1
        This is a little frustrating!
        Anyone have any other ideas as to what could be wrong? I very much want my company to adopt this as our primary monitoring tool, but I need the mysql check to work...
        Thanks so much for your help thus far guys...
        brian
        • KarmaPolice
          • Oct 2005
          • 95
          how do you have the item defined on the front end?
          • bdub
            • Apr 2006
            • 24
            I'm using the stock "Application.MySQL is Alive" item.
            Type: Zabbix Agent
            Key: mysql.ping (changed from mysql[ping] as previously reccomended)
            Type of Info: Numeric (float)
            Units: blank
            Multiplier: Do Not Use
            Update Int.: 60 seconds
            keep in history: 7 days
            keep trends: 365
            status: monitored
            store value: as is
