HPUX specific issues
  • fmtaylor2
    • May 2006
    • 66
    I am running B9 on a number of boxes.
    The linux systems are not giving me any problems (other than what is noted in the forums). I am however haveing some problems with my HPUX systems that don't seem to be covered in the forums.
    Specifically, net.if.in and out are not functioning. the devices are lan0 and lan1, but I can not get any data (not supported).
    Also proc.num[whatever] does not seem to function.
    Also, in what is probably a related error, I can not seem to find a zabbix_agentd.tmp file. It shows up on both my linux and solaris systems, but not on my HPUX systems.
    Ideas?
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    ZABBIX 1.1beta9 has some outstanding issues. It changes status of Float item to UNSUPPORTED if the server receives integer value from an agent. This is a critical bug which is already fixed in CVS.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • fmtaylor2
      • May 2006
      • 66
      soooo
      Is there a diff or a patch or something that I can get to solve this particular issue??
      Please..
