Pictures cannot be displayed. The path is pointing somewhere else.
  • kanour
    • May 2006
    • 105
    I am getting a lots of these errors from apache log for different pictures.
    File does not exist: /usr/share/images/gradients/table_head.gif
    I compile the sources with preffix /usr.
    But why should pictures be located in /usr/images ? I thought the path should point to the web directory?
    Is there any fix for this or should I create that image directory in /usr and move the pictures there?
  • just2blue4u
    • Apr 2006
    • 347
    where did you move the frontend to?
    I just moved the whole data from folder frontend/php (located in zabbix tar.gz) to /var/www/html/zabbix/ . this works for me...
    Big ZABBIX is watching you!
    (... and my 48 hosts, 4513 items, 1280 triggers via zabbix v1.6 on CentOS 5.0)
    • kanour
      • May 2006
      • 105
      Because I run virtual hosts I have in ~/www
      • just2blue4u
        • Apr 2006
        • 347
        then copy all data from frontends/php to ~/www/ ... that should do it.
        • kanour
          • May 2006
          • 105
          But I have it all there. Even the image folder.
          Should I do copy and rewrite it all??? Can I damage something? Will it help?
          • just2blue4u
            • Apr 2006
            • 347
            which version do you use?
            which php-files contain the image path string ?
            • kanour
              • May 2006
              • 105
              I use version 1.1beta9
              I don't know which files the path is defined in?
              • just2blue4u
                • Apr 2006
                • 347
                the image table_head.gif is defined in css.css .
                If your css differs to the one supplied in tar.gz, copy the css from archive into ~/www/
                or try to insert full (absolute) path in css.css (line 845 & 3296)...
                • kanour
                  • May 2006
                  • 105
                  I think that everythink is fine:
                  url(images/gradients/table_head.gif)
                  That should work.
                  The only posibility then is config file for apache. Could be the error somewhere there?
                  • kanour
                    • May 2006
                    • 105
                    Still nothing so I created the folder in /usr/share/images and it works now.
                    I dont know where is the problem.
