Server dies on Solaris 10
  • ptribble
    • May 2006
    On Solaris 10 sparc, 1.1beta9, built with the Sun supplied gcc, zabbix_server keeps shutting down.
    The error in the log is:
    022802:20060512:020715 Failed to connect to database: Error: Can't connect to local MySQL server through socket '/tmp/mysql.sock' (146)
    022800:20060512:020715 One server process died. Shutting down...
    022800:20060512:020715 ZABBIX server is down.
    It doesn't tell me why it couldn't connect - the database is up and running and is reporting no errors.
    Besides, shouldn't it retry the connection rather than just exit?
  • rue
    • May 2006
    • 43
    sure, that your mysql-Server communicates through /tmp/mysql.sock?
    I'm not sure, but on my linux machine the socket for the mysqld is
    /var/lib/mysql/mysql.sock
    You can configure this option in /etc/zabbix/zabbix_server.conf
    Look for:
    #DBSocket=/tmp/mysql.sock
    This is the default. Just uncomment this line and point it to your mysql.sock, e.g:
    DBSocket=/var/lib/mysql/mysql.sock
    and you should be fine (after zabbix_server restart...)
    greetings
    RĂ¼
    OFH Excuse #333:
    A plumber is needed, the network drain is clogged
    • ptribble
      • May 2006
      That's not it
      Yes, I'm sure.
      It works fine for several hours, then exits.
