De-linking Templates
  • jangliss
    • Nov 2005
    • 9
    Not sure whether to consider this a bug, or a feature request, but here it goes. I have been playing with the latest beta (beta 9 at this time), and have bene using some templates to see how flexible they are, and stumbled across a small "issue".
    It basically boils down to "if you delete a template, you delete the linked item". IE, if I delete a template item that checks disk space on E: for example, all hosts that have that item lose it. I think as a nice feature, it'd prompt you to either delink the item, or deleting the item. Without testing, I believe the same is true of host templates being deleted.
    I also stumbled across a similar issue with hosts. If you decide not to use a template on a host any more (select host, change "use template" back to "..."), any items from the host template are removed from the host. While I can understand the idea behind this, I think I'd rather be prompted to remove the items, or just unlink them.
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    You're absolutely right. We'll try to have it implemented in next beta.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
