Beta9 - Can it be used for production yet?
  • johanpre44
    • Apr 2006
    • 40
    I've played around with Zabbix 1.1Beta9 in a test environment and found that it is brilliant (compared to Nagios and Cacti with Threshold plugin). I also haven't really found any issues/bugs with Zabbix that is mentioned on this forum (actually I haven't found any during my testing)
    I urgently need a monitoring/alerting/graphing solution and would like to use Zabbix, but I'm worried if the data that it collects will be usefull when the production/stable version is released. Will there be any changes/fixes to the MySQL zabbix db structure, or will the changes/fixes mostly be on the frontend and agents?
    Any idea of when the production/stable version of 1.1 will be released? Another month, or 2, or more?
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Please do not use 1.1beta9 for production. It has several critical issues which may or may not affect your setup. ZABBIX v1.1beta10 is about to be released. ZABBIX v1.1 is very very close.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • johanpre44
      • Apr 2006
      • 40
      Ok,
      I think I can still wait a while then, thanks for the reply.
