ZABBIX 1.1beta10: Known issues & patches
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    The following issues confirmed at the moment:
    1. Graphs are empty for periods of more than 24h (confirmed)
    Fix file include/classes/graph.inc.php, function selectData(), replace the IF by the following code:
    if($this->period<=24*3600)
     array_push($sql_arr,
     "select itemid,round(900*(mod(clock+$z,$p))/($p),0) as i,count(*) as count,avg(value) as avg,min(value) as min,max(value) as max,max(clock) as clock from history where itemid in ($str) and clock>=".$this->from_time." and clock<=".$this->to_time." group by itemid,round(900*(mod(clock+$z,$p))/($p),0)",
     "select itemid,round(900*(mod(clock+$z,$p))/($p),0) as i,count(*) as count,avg(value) as avg,min(value) as min,max(value) as max,max(clock) as clock from history_uint where itemid in ($str) and clock>=".$this->from_time." and clock<=".$this->to_time." group by itemid,round(900*(mod(clock+$z,$p))/($p),0)");
    else
     "select itemid,round(900*(mod(clock+$z,$p))/($p),0) as i,sum(num) as count,avg(value_avg) as avg,min(value_min) as min,max(value_max) as max,max(clock) as clock from trends where itemid in ($str) and clock>=".$this->from_time." and clock<=".$this->to_time." group by itemid,round(900*(mod(clock+$z,$p))/($p),0)");
    2. SQL errors in frontend (confirmed)
    "Go to latest data and select Graph (for example processor load). After this i click monitoring link (below zabbix logo) to get back to mainpage i get these errors."
    Fixed in CVS. Wait for in 1.1beta11.
    3. Windows agent returns wrong data for agent.ping (confirmed)
    Fixed in CVS. Download binary ZabbixW32.exe from CVS or wait for 1.1beta11.
    4. Duplicate graphs when adding graph elements to a template (confirmed)
    Fixed in CVS. Wait for 1.1beta11.
    5. ZABBIX executes all actions (confirmed)
    Try attached actions.c. Replace src/zabbix_server/actions.c, recompile ZABBIX server and report any success/failure stories.
    6. Overview does not expand macros $1, $2, ... (confirmed)
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
  • erisan500
    • Aug 2005
    • 285
    Cool, thanks, works like a charm
    EriSan
    • dminstrel
      • Apr 2005
      • 72
      At which line number? Is it the IF that starts by this:
      if(isset($this->stime))
      # $this->to_time=$this->stime+24*3600;
      Thanks!
      • erisan500
        • Aug 2005
        • 285
        No, it's the if that starts like: if($this->period<=24*3600)
        (line 742)
        EriSan
        • tibor
          • May 2006
          Thanks, works great!
          • marius
            • Apr 2006
            • 47
            is it me, or is the new actions.c not sending out any emails?
            • n9yty
              • May 2006
              src/libs/zbxsysinfo/unknown/net.c
              There are two functions defined NET_IF_OUT. NET_IF_TOTAL is missing, so I assume the second NET_IF_OUT should be NET_IF_TOTAL ?
              • Wido
                • Mar 2006
                • 23
                Same problem here.
                • jamkad
                  • Sep 2005
                  • 27
                  Is this bug with email also fixed with this new actions.c?
                  - email shows allways trigger ON, even if it was OFF
