MySQL result error in db.inc.php for Hosts
  • jodrell
    • Jan 2005
    I've just installed alpha4 and it seems to be OK as far as setting up users (I'm following the help onsite) but when I get to setting up Hosts I'm getting the following errors underneath the CONFIGURATION OF HOSTS, and before the headings (underneath which it says No hosts defined - which is incorrect as I've set one up and can see it in the database)
    Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in /var/www/html/zabbix/include/db.inc.php on line 103
    Warning: mysql_num_rows(): supplied argument is not a valid MySQL result resource in /var/www/html/zabbix/include/db.inc.php on line 141
    I've tried to set the host up again and it tell me I can't because it's already there . . . any ideas???
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Is it upgrade or fresh install? In case of upgrade, you have to apply database patches.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • jodrell
      • Jan 2005
      It's a fresh install but I did have to reinstall after I downloaded from a link that was pointing to the alpha1 version instead. Has the database changed from then?? If so I may need to rebuild the database??
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        You have to apply patches. Instructions can be found in the ZABBIX Manual.
        Alexei Vladishev
        My Twitter
        • jodrell
          • Jan 2005
          Thanks, as I hadn't done anything I just dropped the database and rebuilt it with the alpha4 sql
