On upgrade of beta11 from beta9 my agentd processes on the zabbix server die a terrible death when I restart zabbix_server.
FC4, server beta11 and agentd beta11
My init.d script is below:
# base zabbix dir
BASEDIR=/usr
# PID file
PIDFILE=/var/tmp/zabbix_server.pid
# binary file
ZABBIX_SUCKERD=$BASEDIR/bin/zabbix_server
# logic section (below here) does NOT normally need any modification
# establish args
ERROR=0
ARGV="$@"
if [ "x$ARGV" = "x" ] ; then
ARGS="help"
fi
# perform action based on args
for ARG in $@ $ARGS
do
# check if PIDFILE exists and ensure is not zero size and react accordingly
if [ -f $PIDFILE ] && [ -s $PIDFILE ] ; then
PID=`cat $PIDFILE`
if [ "x$PID" != "x" ] && kill -0 $PID 2>/dev/null ; then
STATUS="zabbix_server (pid $PID) running"
RUNNING=1
else
STATUS="zabbix_server (pid $PID?) not running"
RUNNING=0
fi
else
STATUS="zabbix_server (no pid file) not running"
RUNNING=0
fi
# parse arg and react accordingly
case $ARG in
start)
if [ $RUNNING -eq 1 ]; then
echo "$0 $ARG: zabbix_server (pid $PID) already running"
continue
fi
if $ZABBIX_SUCKERD ; then
echo "$0 $ARG: zabbix_server started"
else
echo "$0 $ARG: zabbix_server could not be started"
ERROR=3
fi
stop)
if [ $RUNNING -eq 0 ]; then
echo "stop called - in running eq 0"
echo "$0 $ARG: $STATUS"
continue
fi
if kill $PID ; then
echo "$0 $ARG: zabbix_server process(es) stopped"
else
echo "$0 $ARG: zabbix_server process(es) could not be stopped"
ERROR=4
fi
restart)
echo "$0 $ARG: zabbix_server not running, trying to start"
else
ERROR=5
fi
else
if kill $PID ; then
echo "$0 $ARG: zabbix_server restarted"
else
ERROR=3
fi
else
echo "$0 $ARG: zabbix_server could not be restarted"
ERROR=6
fi
fi
echo "usage: $0 (start|stop|restart|help)"
cat <<EOF
start - start zabbix_server
stop - stop zabbix_server
restart - restart zabbix_server if running by sending a SIGHUP or start if not running
help - this screen
EOF
ERROR=2
esac
done
exit $ERROR
# base zabbix dir
BASEDIR=/usr
# PID file
# binary file
# establish args
ERROR=0
ARGV="$@"
ARGS="help"
fi
for ARG in $@ $ARGS
do
PID=`cat $PIDFILE`
RUNNING=1
else
RUNNING=0
fi
else
RUNNING=0
fi
case $ARG in
start)
continue
fi
else
ERROR=3
fi
stop)
continue
fi
if kill $PID ; then
else
ERROR=4
fi
restart)
else
ERROR=5
fi
else
if kill $PID ; then
else
ERROR=3
fi
else
ERROR=6
fi
fi
cat <<EOF
help - this screen
EOF
ERROR=2
esac
done
exit $ERROR
