Im starting to use Zabbix 1.1.4 and noticed some problems or things i havent seen yet correctly or read :
1 - Trend : Seems not possible to change this valor (stuck to 365) when editing or adding an item.
2 - Actions (alerts) : they seem to not activate when a triggers is going on or off, trigger is ok and is working but alert do not fire.
3- Had to correct init script for zabbix_server for suse 9.2, -u parameters to launch the process under zabbix user for example was misplaced.
4- Image data script seem to fire errors when used, images have to be all in the database directory already and need to get copied from several different directories in the sources.
5- Still not able to get data for disk usage (using zabbix agent on linux suse 9.2), though we get information about inodes and op/sec.
6- Restarting mysql cause zabbix-server to crash, well not biggy once you know it
I m going to run zabbix 1.0 for production and continue to test 1.1.4 for testing, but ... really nice job there
Zabbix is awesome.
Pascal
Zabbix is awesome.Pascal
