zabbix on openBSD
  • limo
    • Dec 2004
    • 192
    zabbix on openBSD
    I compiled zabbix on openBSD and everythink went well except there is some error in check_security which crashes zabbix_agentd when there is a connection from non-allowed IP.
    Maybe some incompatibility in sockets?
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    1. Any warning or error messages during compilation?
    2. Why do you think the problem is in check_security()?
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • limo
      • Dec 2004
      • 192
      check_security on openbsd
      Here is the message
      Jan 26 20:00:10 elvira zabbix_agentd: stack overflow in function check_security
      More sent to email. It was too much..
      Thank you !
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Thanks for the information you sent! I see nothing wrong, no compiler complains.
        Just a guess, perhaps you have some (very) low limits on maximum available stack size?
        Alexei Vladishev
        My Twitter
        • limo
          • Dec 2004
          • 192
          openbsd3.5
          This is standard installation of openbsd 3.5 . I dod not set some kernel parameters..
          But I found that when there is LogFile and DebugLevel set in config to some value, problem is solved..
