I updated my zabbix 1.0 installation to final 1.1 this week and played around with linked templates. But one thing which not works are graphs defined in a template. I always get an SQL error.
What i did:
1. Configuration => Hosts
2. clicked "Graphs" of my template
3. "Create graph"
4. adden graph name "CPU load"
5. saved graph
6. choosed Group: all / Host: all to see all graphs (The newly created graph has no "Hosts")
7. clicked "Edit" of the created graph
8. "Add item" => selected a "parameter" of the template => "save"
9. Now i get this messages/errors:
Graph 'CPU load' added
Added Item 'Processor load (1min)' for graph ''
Added Item 'Processor load (1min)' for graph 'CPU load'
SQL error: Duplicate entry 'CPU load' for key 2
Query: insert into graphs (name,width,height,yaxistype,yaxismin,yaxismax,tem plateid,show_work_period,show_triggers) values ('CPU load',900,200,0,0.0000, 100.0000,118,1,1)
No graph with graphid=[316]
"118" in the query is the graph itself
But the item was created and adding a additional item don't gives an new error. Anyway, the graph don't works correctly. Maybe someone can reproduce this or has a fix for it?
Thank you
Urs
What i did:
3. "Create graph"
5. saved graph
Thank you
Urs
