2.4.0 trigger operator change - old ones no longer supported?
  • jkuc
    • Jun 2014
    This isn't alpha/beta version feedback, but I couldn't see a better section to post this thread in. While reading the changelog for Zabbix 2.4.0 I've noticed an unsettling statement:
    In additional development, the syntax of three existing operators has been changed with the aim of making trigger expressions easier to read. Thus:
    • # (not equal) is now expressed with <>
    • & (logical AND) is now expressed with and
    • | (logical OR) is now expressed with or
    Note that the old operators are no longer supported, so the new ones have to be used instead.
    (source) https://www.zabbix.com/documentation...gger_operators
    Does this mean that all triggers using # / & / | in their expressions will become unsupported upon updating to 2.4.0?
    Are you planning to include some sort of conversion in the database update script?
    Or maybe I have misunderstood that sentence?
  • Andreas Bollhalder
    • Apr 2007
    • 144
    I was thinking about the same. If I check the manuals from 2.2 and 2.4, it seems there is no version who accept both operators.
    Either the documentation is incomplete or the Zabbix 2.4 server must replace the operators when starting the first time. If not, then we are stuck on the migration...
    @Zabbix Devs:
    Please clarify this issue.
    Andreas
    Zabbix statistics
    Total hosts: 380 - Total items: 12190 - Total triggers: 4530 - Required server performance: 224.2
      • Apr 2007
      • 144
      So, no one knows what happens? No one migrated to 2.4?
      Zabbix statistics
      • tvtue
        • Sep 2012
        • 71
        I have done an upgrade and the operators where converted automatically.
        regards
        timo
          • Apr 2007
          • 144
          Hello Timo
          Thanks a lot for your confirmation. One point removed from my checklist ;-)
          Cheers
          Andreas
          Zabbix statistics
