Zabbix 6.0 alpha - Native high-availability and load balancing
  • Spectator
    • Sep 2021
    • 71
    As I read in the roadmap, Zabbix 6 will be able to:
    - Proxies to provide automatic load balancing and HA
    - Native HA setup for Zabbix Server
    Has anyone tried this?
    Does anyone know any documentation on how to set this up?
  • Glencoe
    Zabbix developer
    • Oct 2019
    • 152
    It's not in the latest alpha yet.
    • Spectator
      • Sep 2021
      • 71
      Thanks your answer.
      Can you tell us when we will be able to try this feature around?
      • Glencoe
        Glencoe commented
        Presumably, in the next alpha. In a week or two.
    • Spectator
      • Sep 2021
      • 71
      Thanks for your reply, we are very much looking forward to this new feature
      • Spectator
        • Sep 2021
        • 71
        "Alexei Vladishev added a comment - 2021 Oct 12 11:26
        This solution is just a much simpler alternative of pacemaker based HA setups. The next step is to introduce load-balancing and HA for proxies in 6.2 and then true horizontal scalability, which would require significant changes of the way how Zabbix server works. It is already in the roadmap: https://www.zabbix.com/roadmap
        Source: https://support.zabbix.com/browse/ZBXNEXT-6923
        Do I see well then that the proxy HA and load-balance functions will not appear in the 6.0 LTS release?
        I didn't see proxy HA and LB functions in the 6.2 roadmap ...
        I see the entry "Proxies to provide automatic load balancing and HA" in the 6.0 LTS roadmap, but without the "Ready" or "in dev" flags. Does this mean that this item will not be included in Zabbix 6.0 LTS?
        If we’re only thinking about LTS versions, the proxy HA and LB features will only be available to us in Zabbix 7.0 LTS, right?
        • Glencoe
          Glencoe commented
          Proxy load balancing is planned but is not likely to make it in 6.0. 6.2 or 6.4 is a more realistic assumption.
        • Spectator
          Spectator commented
          Glencoe, thanks your answer.
