Zabbix 3 maps not refreshing
  • WannaBe
    • May 2015
    I've been playing a little bit with zabbix 3.0 for past couple days and I've noticed that maps are not refreshing at all. Is it just me or does anyone experience same problem?
  • Atsushi
    • Aug 2013
    • 2028
    Me too.
    Refresh logic isn't incorporated in the HTML.
    (I checked by Build 56851)
    Now, It seems to implement the screen and map display functions for each user.
    ZBXNEXT-2682
    creating and sharing visualisation objects
    I think that the work has been delayed because of this development.
    There are also other bug in the map.
    If it does not seem to have been improved in the beta, let's point out again.
    • Atsushi
      • Aug 2013
      • 2028
      I think this is bug ZBX-9968.
      Fix Version is not 3.0.0???
      I testing with 3.0.0rc1. But, this problem is unimproved.
      It may be improved after 3.0.1. :-(
      see:
      ZBX-9968 monitoring -> maps & discovery not updated automatically
      • incama
        • Jan 2015
        • 66
        Still a problem in RC3.
        • Ordnas
          • Mar 2015
          • 13
          Still a problem in Zabbix 3.0 LTS
          • sergeytuchkov
            • Aug 2014
            refresh map?
            Good afternoon, faced with the same problem. The card is not automatically updated. Is there a solution to get around this problem?
            • legolastheelf
              • Apr 2016
              any news?
              i also have network maps that doesn't refresh. someone have news about that?
              • boyemillar
                • Nov 2015
                • 33
                We had the same problem too... Just incorporate your Map into a Screen and then the Screen will refresh as the logic is built into screens.
                • Atsushi
                  • Aug 2013
                  • 2028
                  I tried to test by developer release.
                  r60049 looks like the map is updated every 30 seconds.
                  However, the following string in the browser page title is not displayed.
                  [refreshed every 30 sec.]
                  And, ZBX-9968 was status changed to CLOSED.
                  Probably in the next release(3.0.3) to be fixed.
                  • cabezza87
                    • Jan 2012
                    I've installed zabbix 3.0.3 and maps section it is still not refreshing. In the ticket https://support.zabbix.com/browse/ZBX-9968 says Fix Version/s: 3.0.3rc1 will be this bug corrected in the next release?
                    Thanks.
                    • Atsushi
                      • Aug 2013
                      • 2028
                      I tried 3.0.3.
                      Map is updated every 30 seconds.
                      But, page title is not display '[refreshed every 30 sec.]'.
                      • cabezza87
                        • Jan 2012
                        Originally posted by Atsushi
                        I tried 3.0.3.
                        Well it seems that I misunderstanding something because while it seems to be async calls to jsrpc.php?output=json-rpc every 30 sec, the content of the map is always the same.
                        Several items on one of my maps are triggers and even if I force them to change its state maps shows the same icons. If I refresh the map (by presing F5) I then see the new states.
                        Guido.-
                        • Atsushi
                          • Aug 2013
                          • 2028
                          In my environment I did not need to press the F5.
                          Please try to wait until the map is refreshed after the Zabbix has detected a fault.
                          And, Please try to check the time stamp at the bottom right of the map of the image.
