geomap and host connection
  • Cramac
    • Sep 2014
    • 91
    Hello.
    Is it possible to add links between host? and editing the position on the map?
    Всем привет.
    Будет ли реализована на геокарте связь между узлами и редактирование позиции узла на карте?
  • dstrickler
    • Mar 2022
    • 10
    I don't see a way to do this, but the software that Zabbix is using to create the maps certainly supports it. I hope that in future versions they allow this, and allow the thickness of the lines to be driven off of a metric like ethernet throughput.
    • dstrickler
      • Mar 2022
      • 10
      As a followup, it is possible to create a map of your hosts and show the links between them. While that doesn't have a map under it, it's till a good start.
      You can find other Zabbix tips I'm posting at https://dstrickler/blog
