3.0 - add the group/item menu in latest data
  • godfader
    • Jul 2012
    • 9
    Is it possible to restore this function?
    don“t know if its a bug or a feature
  • Atsushi
    • Aug 2013
    • 2028
    Please see manual for 2.4.
    That selection was deleted at version 2.4.
    But, The filter function has been enhanced.
    The section no longer has the host and host group selection dropdowns. Instead, those two choices can be made within an expanded filter section, which can be used flexibly for displaying the exact set of items you want. Additonally, items now have checkboxes in the listing.
    • godfader
      • Jul 2012
      • 9
      But is it possible to restore the dropdown?
      The filter menu is very big and for a simple check that dropdown, for me was simpler/better.
      • richlv
        • Oct 2005
        • 3112
        unfortunately, restoring the dropdowns is not possible (without hacking the frontend).
        the new filter is definitely less convenient if all you want to do is single host/group selection.
        consider creating a new feature request
        • godfader
          • Jul 2012
          • 9
          How/Where can I do that? Thanks!
          • richlv
            • Oct 2005
            • 3112
            see https://support.zabbix.com/
