Agent Ecryption problem
  • erisan500
    • Aug 2005
    • 285
    Using Zabbix 3.0.0rc1
    I just tried to get encrypted communications going between an agent on Windows server 2012 R2 and Zabbix 3.0.0rc1 (on Centos 6.7 64bit).
    I defined in the agent config file on the windows server the following:
    TLSConnect=tls (tried both upper and lower case)
    TLSAccept=tls (tried both upper and lower case)
    TLSPSKIdentity=myprivatesharedkey
    All other TLS parameters are left commented out.
    When i start the agent it says:
    zabbix_agentd.exe [668]: ERROR: cannot start service [Zabbix Agent]: [0x0000041D] The service did not respond to the start or control request in a timely fashion.
    Looking at the zabbix_agentd.log file i noticed that TLS Support = NO, although the release notes says it has been fixed.
    Thx in advance.
    EriSan
  • glebs.ivanovskis
    • Jul 2015
    • 237
    Firstly, precompiled Windows agents come without encryption support compiled in. This is something to be fixed, but you can speed up the process by voting on ZBXNEXT-3047.
    Secondly, TLS parameters you provide do not seem to be correct. Please refer to the documentation.
    • erisan500
      • Aug 2005
      • 285
      Voted for ZBXNEXT-3047
      EriSan
      • dedisoft
        • Dec 2013
        • 18
        If you are interrested, I've compiled the agent version 3.0.1 for Win64.
        Download it here : http://dl.free.fr/mEJSaErXp
        Visual C++ 2015 redistributable is required.
        OpenSSL 1.0.2.7 is used (and included).
        Regards,
        PS : I've juste seen that he was available on https://support.zabbix.com/browse/ZBXNEXT-3047 too...
