zabbix 1.3 beta login
  • dsipe
    • Oct 2006
    • 184
    Hy,
    i can't login in zabbix 1.3 using 'admin' account / no password.
    Anything as changed since zabbix 1.1.3 ?
    thanks
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    No nothing has changed. Default user name is "Admin" with no password.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • dsipe
      • Oct 2006
      • 184
      i reinstall everything.
      i pass the setup frontend with success.
      1) if i don't close my web browser, it always ask me to process the setup
      2) if i open a new one, i've got the following error :
      Non-static method COpt::savesqlrequest() should not be called statically[/srv/www/htdocs/zabbix/include/db.inc.php:167]
      ??? Any ideas
      thanks
      • LEM
        • Sep 2004
        • 112
        Additional info for this login issue in 1.3beta1
        Additionnal infos for this login issue with 1.3beta1 using 'Admin'/ blank passwd :
        mysql> select * from usrgrp;
        | usrgrpid | name |
        | 2 | Database administrators |
        | 6 | Head of IT department |
        | 3 | Network administrators |
        | 4 | Security specialists |
        | 1 | UNIX administrators |
        | 5 | WEB administrators |
        | 7 | Zabbix administrators |
        7 rows in set (0.00 sec)
        mysql> select * from rights;
        | rightid | groupid | type | permission | id |
        | 1 | 1 | 0 | 0 | 0 |
        | 2 | 1 | 0 | 0 | 0 |
        | 3 | 2 | 0 | 0 | 0 |
        3 rows in set (0.00 sec)
        mysql> select * from users_groups;
        Empty set (0.01 sec)
        Isn't it the cause of "No permissions" ?
        LEM
        • dsipe
          • Oct 2006
          • 184
          may someone help me with the bug encountered in this 1.3 ?
          it seem that i'm the only one who get this COpt::savesqlrequest() problem ..
          I'm using a Suse 10.1 with mysql/php bundled.
          HELP!
          I really want to replace all my existing monitoring software [ nagios+mrtg ] with Zabbix, but it'll be better to get it work
          • Alexei
            Founder, CEO
            • Sep 2004
            • 5654
            Please do not use 1.3 in production! This is very alpha software which is absolutely not ready for life systems. Consider using 1.1.4 instead.
            All known issues of 1.3 will be addressed in 1.3.1.
            Alexei Vladishev
            My Twitter
            • dsipe
              • Oct 2006
              • 184
              of course Alexie.
              wha's difficult for me at the right moment is that i'd like to put Zabbix into production, but the amount of work to put the v1.1.4 is so amazing for me, that i'm afraid to have to restart from scratch when v1.4 'll be ready
              It's not a real problem at the moment having a beta solution to monitor the all system.
              I just want to create all the things ONE TIME [ items, triggers, actions ... ] and be sure not the recreate them for next version.
              when is the release date for 1.3.1?
              • gauntletguy
                • Nov 2006
                i bet you are using php5, it seems as though zabbix 1.3 does not work on php5, from the errors it looks like alot of deprecated functions, etc, are used, you can fix it by removeing php5 and installing php4
                • dsipe
                  • Oct 2006
                  • 184
                  GOOD!
                  it work with PHP4
                  thanks a lot
                  nb: i really don't understand why zabbix 1.1.4 run ok and not 1.3 ???
