Schema.sql Errors
  • ssullivan
    • Oct 2006
    Schema.sql Errors
    Zabbix 1.3
    Os: Debian:
    Mysql:4.0.24_Debian-10sarge2-log
    Here is the error I get.
    cat schema.sql | mysql -u(username) -p(password) zabbix
    ERROR 1064 at line 245: You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near 'serial ,
    nodeid bigint unsigned DEFAULT '0' NOT NULL,
    ite
    Can anybody help?
  • brick
    • Nov 2006
    http://dev.mysql.com/doc/refman/5.0/...-overview.html
    so, just replace "SERIAL" with "BIGINT UNSIGNED NOT NULL AUTO_INCREMENT UNIQUE"
