7.0.0 beta2 - No info for failed checks
  • fwilke
    • Mar 2024
    I updated today from beta1 to beta2.
    Since then I figured if a check doesn't work the red info icon is missing and you get no hint what is wrong. I figured this out, because I am in the process of developing a template. It is more than hard to find out, why a discovered item has no data even though the tests within item configuration and item prototype configuration work well.
  • fwilke
    • Mar 2024
    Update...
    To test I installed a new server with 6.4.13, imported my template and all worked...
    I also deleted the host from the 7.0 server and created it again. It doesn't get any data. Neither those from my template no ICMP Ping. Even though that the HTTP requests happen. Tried to revert back to 7.0beta1 without success.
