Database schema problems 1.3.1
  • popek90
    • Oct 2006
    They are problems with adding multiple values to service_alarms, services_time tables. I received error 'Duplicate entry '1' for key 1 [1062]'.
    To resolve problem add auto_increment to primary keys in tables.
    I've made changes on schema exported using mysqldump utility.
    Use carefuly! schema exported using mysql deletes table before inserting a new one.
    DROP TABLE IF EXISTS `service_alarms`;
    CREATE TABLE `service_alarms` (
    - `servicealarmid` bigint(20) unsigned NOT NULL default '0',
    + `servicealarmid` bigint(20) unsigned NOT NULL auto_increment,
    `serviceid` bigint(20) unsigned NOT NULL default '0',
    `clock` int(11) NOT NULL default '0',
    `value` int(11) NOT NULL default '0',
    @@ -748,8 +748,8 @@
    DROP TABLE IF EXISTS `services_times`;
    CREATE TABLE `services_times` (
    - `timeid` bigint(20) unsigned NOT NULL default '0',
    + `timeid` bigint(20) unsigned NOT NULL auto_increment,
    `type` int(11) NOT NULL default '0',
    `ts_from` int(11) NOT NULL default '0',
    `ts_to` int(11) NOT NULL default '0'
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Thanks for reporting this! Note that the patch is not correct. While I expect no problems running standalone ZABBIX server, it cannot be used in distributed setup.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • atrice
      Eventid and alertid auto-increment
      I am running zabbix 1.3.1 on RHEL4, x86_64, with MySQL-server-standard-5.0.27-0.rhel4 from the rpm provided by MySQL. I had query fail errors in the server log about duplicate keys in the events and alerts. I think there is a problem with mysql 5 that prevents auto_increment from being set. To fix it, I used alter_table as shown here. Basically drop the eventid column and recreate it with auto_increment set. Do the same thing for alerts, but drop and recreate the alertid column.
      mysql> ALTER TABLE events DROP COLUMN eventid;
      mysql> ALTER TABLE events ADD eventid INT UNSIGNED NOT NULL AUTO_INCREMENT,
      ADD PRIMARY KEY (eventid);
