I cannot get zabbix to compile on Solaris 10, I configured it with:
./configure --enable-server --with-mysql --prefix=/opt/zabbix
Undefined first referenced
symbol in file
mysql_autocommit ../libs/zbxdbhigh/libzbxdbhigh.a(db.o)
__UINT64_C nodewatcher/libzbxnodewatcher.a(nodewatcher.o)
ld: fatal: Symbol referencing errors. No output written to zabbix_server
collect2: ld returned 1 exit status
*** Error code 1
make: Fatal error: Command failed for target `zabbix_server'
Current working directory /export/home/jas/zabbix-1.3.1/src/zabbix_server
*** Error code 1
The following command caused the error:
failcom='exit 1'; \
for f in x $MAKEFLAGS; do \
case $f in \
*=* | --[!k]*);; \
*k*) failcom='fail=yes';; \
esac; \
done; \
dot_seen=no; \
target=`echo install-recursive | sed s/-recursive//`; \
list='alerter housekeeper pinger poller timer trapper nodewatcher utils'; for subdir in $list; do \
echo "Making $target in $subdir"; \
if test "$subdir" = "."; then \
dot_seen=yes; \
local_target="$target-am"; \
else \
local_target="$target"; \
fi; \
(cd $subdir && make $local_target) \
|| eval $failcom; \
done; \
if test "$dot_seen" = "no"; then \
make "$target-am" || exit 1; \
fi; test -z "$fail"
make: Fatal error: Command failed for target `install-recursive'
*** Error code 1
failcom='exit 1'; \
case $f in \
*=* | --[!k]*);; \
esac; \
done; \
dot_seen=no; \
list=' libs zabbix_server'; for subdir in $list; do \
dot_seen=yes; \
else \
fi; \
|| eval $failcom; \
done; \
fi; test -z "$fail"
*** Error code 1
failcom='exit 1'; \
case $f in \
*=* | --[!k]*);; \
esac; \
done; \
dot_seen=no; \
list='src'; for subdir in $list; do \
dot_seen=yes; \
else \
fi; \
|| eval $failcom; \
done; \
fi; test -z "$fail"
symbol in file
*** Error code 1
*** Error code 1
failcom='exit 1'; \
case $f in \
*=* | --[!k]*);; \
esac; \
done; \
dot_seen=no; \
dot_seen=yes; \
else \
fi; \
|| eval $failcom; \
done; \
fi; test -z "$fail"
*** Error code 1
failcom='exit 1'; \
case $f in \
*=* | --[!k]*);; \
esac; \
done; \
dot_seen=no; \
dot_seen=yes; \
else \
fi; \
|| eval $failcom; \
done; \
fi; test -z "$fail"
*** Error code 1
failcom='exit 1'; \
case $f in \
*=* | --[!k]*);; \
esac; \
done; \
dot_seen=no; \
dot_seen=yes; \
else \
fi; \
|| eval $failcom; \
done; \
fi; test -z "$fail"
