Macros
  • cowboy8
    • Feb 2005
    Macros
    Great product. Does anyone have a list of macros (example: {HOSTNAME}) that you can use in zabbix. Would it be possible to have the ability to use macros as the name of a trigger. I am very instrested in developing a map that shows the last time a file was changed and I would like the trigger name to show as a date {DATE}
    Thanks Keep up the good work
  • mary nancy
    • Jul 2005
    • 125
    Hi
    Macros simplify the configuration. I would like to know whether there is a macro which will generate the value of the trigger expression in the trigger name.
    Regards
    Nancy
