I have the following templates defined and populated on a server:
Disk free space on / vfs.fs.size[/,free]
Disk free swap space system.swap.size[,free]
Disk total disk space on / vfs.fs.size[/,total]
Disk total swap space system.swap.size[,total]
Disk used space on / vfs.fs.size[/,used]
All are defined as 64bit integers, units of B, data stored and shown as-is. When I apply this template to a server I seem to be getting wacky values:
Description (Last value)
Disk free space on / (4.61 MB)
Disk free swap space (1.54 GB)
Disk total disk space on / (17.70 MB)
Disk total swap space (1.99 GB)
Disk used space on / (13.09 MB)
It seems the swap information of free and total are correct but the disk ones are not, going to the server here is the actuals on /:
[root@cooks root]# df -k /
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda2 18556080 13551464 4062004 77% /
[root@cooks root]# df -h /
Filesystem Size Used Avail Use% Mounted on
/dev/sda2 18G 13G 3.9G 77% /
So the above total should read 17.7GB, not MB and the free space should show almost 4GB, not 4.61MB, the used should be 13GB not 13MB. What do I need to change to get these to display the correct values? Available disk space seems to be off no matter about the MB/GB issue as well.
/Chris
/Chris
