1.3.2 BUG? In Screens
  • cecila
    • Jul 2006
    • 16
    While trying to create a screen I selected the grid location and selected the option to add a map. The names of my maps didn't show in the drop down menu so I could not select them. Has anyone else had this problem? Am I missing something?
  • bobrivers
    • Feb 2007
    • 115
    Same problem, and new ones...
    Same problem to me. I'm not able to select a map name.
    In fact, it doesn't work for any dropdown that has a parent. For instance, if you select TRIGGERS OVERVIEW or DATA OVERVIEW, the dropdown will always show "all". It doesn't allow you to select a group (and I have some created).
    Another bug (I think) is in HOST INFO. I have just one host configured and 5 templates (the default ones). It shows me 1 host available and 5 unknown. IMHO the templates are not hosts, so they should be ignored...
    I'm trying to do it using Firefox 1.5.0.3 on a RHEL AS 4 box using version 1.3.2
    • bobrivers
      • Feb 2007
      • 115
      The problems are present in the 1.3.3 version too...
