Multiplier problem within delta (per second) (v1.3.2)
  • medic
    • Feb 2007
    • 58
    I am using zabbix 1.3.2beta and a 64bit arch, if this is important in any way.
    Taking the delta with ifconfig from the interface within 1 second, i get:
    3354500 bytes (per second)
    standard within zabbix without multiplier i get in my database
    1521950969674 (bytes per second)
    now i take a multiplier smaller than 1 (for example 0.1) and i get
    268360 (which is pretty much the value of my ifconfig in kbit/s *10)
    But zabbix frontend shows me 268,36 KKbit/s, thats not very pretty .. so i have to multiply with 10 to have bits/second...
    but a multiplier 10 ends in an entry showing
    15219509696740 in my database ..
    so multipliers greater/equal 1 are broken
    So something's really going crazy here...
    Workaround:
    use float and a multiplier of 0.000001 .. Make the Units "Mbit/s" and it works for me ..
    will try to float around, probably it is a delta/uint-Bug (divisions mostly end in floating point .. interpreting a double as int has strange sideeffects, because the upper and lower part are handled as 2 seperate parts in a float, but as a whole in uint)
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    I think it is fixed in pre-1.1.3. Please test this when 1.1.3 is released and report back.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • medic
      • Feb 2007
      • 58
      Fixed in 1.3.3
      closed
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Thanks for your report!
        Alexei Vladishev
        My Twitter
