Application Uniq ?
  • medic
    • Feb 2007
    • 58
    Application Uniq ?
    I have different types of Hardware i monitor, and i love to use templates, and templates within templates, and so on ..
    But I can't join 2 templates if both have the same Applicationname (e.g. HTTP) even though the one template does all the raw network-checks, the second the agent-based-checks, the third some custom checks, which require binaries not installed on every server ...
    Is it intended, that you can only join Templates with different Applications into one host, or is there a way, one could just "merge" all the Applications with "HTTP" into the ''HTTP-Application-Group''
    best regards
    medic
