Unable to install zabbix.
  • kanour
    • May 2006
    • 105
    Hi, I am trying install zabbix 1.3.2.
    I am unable to "make install.
    I configure it but when I try to make install. It seem it does proceed the make install, but there is nothing in /usr/local/.... directories.
  • kanour
    • May 2006
    • 105
    Configure finishes with this:
    Configuration:
    Detected OS: linux-gnu
    Install path: /usr/local
    Compilation arch: linux
    Compiler: gcc
    Compiler flags: -g -O2
    Linker flags:
    Libraries: -lresolv -lnsl
    Enable server: no
    With database: no
    Enable agent: no
    * Now run 'make install' *
    * Thank you for using ZABBIX! *
    * <http://www.zabbix.com> *
    Make install finishes with this:
    Making install in src
    make[1]: Entering directory `/root/zabbix-1.3.2/src'
    make[2]: Entering directory `/root/zabbix-1.3.2/src'
    make[3]: Entering directory `/root/zabbix-1.3.2/src'
    make[3]: Nothing to be done for `install-exec-am'.
    make[3]: Nothing to be done for `install-data-am'.
    make[3]: Leaving directory `/root/zabbix-1.3.2/src'
    make[2]: Leaving directory `/root/zabbix-1.3.2/src'
    make[1]: Leaving directory `/root/zabbix-1.3.2/src'
    make[1]: Entering directory `/root/zabbix-1.3.2'
    make[2]: Entering directory `/root/zabbix-1.3.2'
    make[2]: Nothing to be done for `install-exec-am'.
    make[2]: Nothing to be done for `install-data-am'.
    make[2]: Leaving directory `/root/zabbix-1.3.2'
    make[1]: Leaving directory `/root/zabbix-1.3.2'
    monit:~/zabbix-1.3.2# ll /usr/local/bin/
    • kanour
      • May 2006
      • 105
      OK, my mistake with configuration command, I forgot to make space.
      I could configure with:
      Enable server: yes
      With Database: PostgreSQL
      Enable agent: yes
      But make install finishes with errors.
      ake[4]: Entering directory `/root/zabbix-1.3.2/src/libs/zbxdbhigh'
      if gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I../../../include -I/usr/local/pgsql/include -g -O2 -MT action.o -MD -MP -MF ".deps/action.Tpo" -c -o action.o action.c; \
      then mv -f ".deps/action.Tpo" ".deps/action.Po"; else rm -f ".deps/action.Tpo"; exit 1; fi
      In file included from action.c:27:
      ../../../include/db.h:42:23: error: libpq-fe.h: No such file or directory
      ../../../include/db.h:118: error: expected specifier-qualifier-list before ‘PGresult’
      make[4]: *** [action.o] Error 1
      make[4]: Leaving directory `/root/zabbix-1.3.2/src/libs/zbxdbhigh'
      make[3]: *** [install-recursive] Error 1
      make[3]: Leaving directory `/root/zabbix-1.3.2/src/libs/zbxdbhigh'
      make[2]: *** [install-recursive] Error 1
      make[2]: Leaving directory `/root/zabbix-1.3.2/src/libs'
      make[1]: *** [install-recursive] Error 1
      make: *** [install-recursive] Error 1
      • BorisL
        • Jan 2007
        • 20
        Here's the main mistake - zabbix 1.3.2 does NOT support PostgreSQL
        • kanour
          • May 2006
          • 105
          It does! http://www.zabbix.com/rn1.3.2.php
          • kanour
            • May 2006
            • 105
            Please can someone confirm that zabbix 1.3.2 can be installed on amd64 with postgreSQL?
            Thank you
