I am rolling RPM's for the current beta 1.3.3 as I did for 1.3.2 and here are the results:
Fedora Core 6
Compiles without issue (--with-ldap seems to no longer be supported)
RedHat Enterprise 4
RedHat Enterprise 3
Tried to compile using stock mysql* 3.23 RPMS, this was expected not to work since this did not work in 1.3.2 either.
I also tried to compile using mysql* 4.1 RPMS downloaded from mysql.com, these were compiled specifically for RHEL3 and this works with zabbix 1.3.2, BUT zabbix 1.3.3 compile fails with:
Fedora Core 6
RedHat Enterprise 4
RedHat Enterprise 3
zabbix_server-evalfunc.o(.text+0xb4): In function `evaluate_LOGSOURCE': /usr/src/redhat/BUILD/zabbix-1.3.3/src/zabbix_server/evalfunc.c:104: undefined reference to `mysql_free_result' zabbix_server-evalfunc.o(.text+0x1a4): In function `evaluate_LOGSEVERITY': /usr/src/redhat/BUILD/zabbix-1.3.3/src/zabbix_server/evalfunc.c:156: undefined reference to `mysql_free_result' zabbix_server-evalfunc.o(.text+0x2b0): In function `evaluate_COUNT': /usr/src/redhat/BUILD/zabbix-1.3.3/src/zabbix_server/evalfunc.c:216: undefined reference to `mysql_free_result' zabbix_server-evalfunc.o(.text+0x3f1): In function `evaluate_SUM': /usr/src/redhat/BUILD/zabbix-1.3.3/src/zabbix_server/evalfunc.c:327: undefined reference to `mysql_free_result' zabbix_server-evalfunc.o(.text+0x70e): In function `evaluate_AVG': /usr/src/redhat/BUILD/zabbix-1.3.3/src/zabbix_server/evalfunc.c:412: undefined reference to `mysql_free_result' zabbix_server-evalfunc.o(.text+0x8c3):/usr/src/redhat/BUILD/zabbix-1.3.3/src/zabbix_server/evalfunc.c:538: more undefined references to `mysql_free_result' follow ../../src/libs/zbxdb/libzbxdb.a(libzbxdb_a-db.o)(.text+0xf): In function `zbx_db_close': /usr/src/redhat/BUILD/zabbix-1.3.3/src/libs/zbxdb/db.c:57: undefined reference to `mysql_close' ../../src/libs/zbxdb/libzbxdb.a(libzbxdb_a-db.o)(.text+0x35): In function `zbx_db_connect': /usr/src/redhat/BUILD/zabbix-1.3.3/src/libs/zbxdb/db.c:89: undefined reference to `mysql_init' ../../src/libs/zbxdb/libzbxdb.a(libzbxdb_a-db.o)(.text+0x71):/usr/src/redhat/BUILD/zabbix-1.3.3/src/libs/zbxdb/db.c:91: undefined reference to `mysql_real_connect' ../../src/libs/zbxdb/libzbxdb.a(libzbxdb_a-db.o)(.text+0x99):/usr/src/redhat/BUILD/zabbix-1.3.3/src/libs/zbxdb/db.c:120: undefined reference to `mysql_errno' ../../src/libs/zbxdb/libzbxdb.a(libzbxdb_a-db.o)(.text+0xdd):/usr/src/redhat/BUILD/zabbix-1.3.3/src/libs/zbxdb/db.c:100: undefined reference to `mysql_select_db' ../../src/libs/zbxdb/libzbxdb.a(libzbxdb_a-db.o)(.text+0xfa):/usr/src/redhat/BUILD/zabbix-1.3.3/src/libs/zbxdb/db.c:110: undefined reference to `mysql_autocommit' ../../src/libs/zbxdb/libzbxdb.a(libzbxdb_a-db.o)(.text+0x10f):/usr/src/redhat/BUILD/zabbix-1.3.3/src/libs/zbxdb/db.c:112: undefined reference to `mysql_errno' ../../src/libs/zbxdb/libzbxdb.a(libzbxdb_a-db.o)(.text+0x11e):/usr/src/redhat/BUILD/zabbix-1.3.3/src/libs/zbxdb/db.c:112: undefined reference to `mysql_error' ../../src/libs/zbxdb/libzbxdb.a(libzbxdb_a-db.o)(.text+0x151):/usr/src/redhat/BUILD/zabbix-1.3.3/src/libs/zbxdb/db.c:102: undefined reference to `mysql_errno' ../../src/libs/zbxdb/libzbxdb.a(libzbxdb_a-db.o)(.text+0x160):/usr/src/redhat/BUILD/zabbix-1.3.3/src/libs/zbxdb/db.c:102: undefined reference to `mysql_error' ../../src/libs/zbxdb/libzbxdb.a(libzbxdb_a-db.o)(.text+0x199):/usr/src/redhat/BUILD/zabbix-1.3.3/src/libs/zbxdb/db.c:93: undefined reference to `mysql_errno' ../../src/libs/zbxdb/libzbxdb.a(libzbxdb_a-db.o)(.text+0x1a8):/usr/src/redhat/BUILD/zabbix-1.3.3/src/libs/zbxdb/db.c:93: undefined reference to `mysql_error' ../../src/libs/zbxdb/libzbxdb.a(libzbxdb_a-db.o)(.text+0x30e): In function `zbx_db_vexecute': /usr/src/redhat/BUILD/zabbix-1.3.3/src/libs/zbxdb/db.c:363: undefined reference to `mysql_query' ../../src/libs/zbxdb/libzbxdb.a(libzbxdb_a-db.o)(.text+0x323):/usr/src/redhat/BUILD/zabbix-1.3.3/src/libs/zbxdb/db.c:365: undefined reference to `mysql_errno' ../../src/libs/zbxdb/libzbxdb.a(libzbxdb_a-db.o)(.text+0x332):/usr/src/redhat/BUILD/zabbix-1.3.3/src/libs/zbxdb/db.c:365: undefined reference to `mysql_error' ../../src/libs/zbxdb/libzbxdb.a(libzbxdb_a-db.o)(.text+0x35f):/usr/src/redhat/BUILD/zabbix-1.3.3/src/libs/zbxdb/db.c:367: undefined reference to `mysql_errno' ../../src/libs/zbxdb/libzbxdb.a(libzbxdb_a-db.o)(.text+0x3a9):/usr/src/redhat/BUILD/zabbix-1.3.3/src/libs/zbxdb/db.c:382: undefined reference to `mysql_affected_rows' ../../src/libs/zbxdb/libzbxdb.a(libzbxdb_a-db.o)(.text+0x47b): In function `zbx_db_vselect': /usr/src/redhat/BUILD/zabbix-1.3.3/src/libs/zbxdb/db.c:613: undefined reference to `mysql_query' ../../src/libs/zbxdb/libzbxdb.a(libzbxdb_a-db.o)(.text+0x4a8):/usr/src/redhat/BUILD/zabbix-1.3.3/src/libs/zbxdb/db.c:616: undefined reference to `mysql_errno' ../../src/libs/zbxdb/libzbxdb.a(libzbxdb_a-db.o)(.text+0x4b7):/usr/src/redhat/BUILD/zabbix-1.3.3/src/libs/zbxdb/db.c:616: undefined reference to `mysql_error' ../../src/libs/zbxdb/libzbxdb.a(libzbxdb_a-db.o)(.text+0x4e0):/usr/src/redhat/BUILD/zabbix-1.3.3/src/libs/zbxdb/db.c:617: undefined reference to `mysql_errno' ../../src/libs/zbxdb/libzbxdb.a(libzbxdb_a-db.o)(.text+0x531):/usr/src/redhat/BUILD/zabbix-1.3.3/src/libs/zbxdb/db.c:632: undefined reference to `mysql_store_result' ../../src/libs/zbxdb/libzbxdb.a(libzbxdb_a-db.o)(.text+0x3dc): In function `zbx_db_fetch': /usr/src/redhat/BUILD/zabbix-1.3.3/src/libs/zbxdb/db.c:505: undefined reference to `mysql_fetch_row' ../../src/libs/zbxdb/libzbxdb.a(libzbxdb_a-db.o)(.text+0x572): In function `zbx_db_insert_id': /usr/src/redhat/BUILD/zabbix-1.3.3/src/libs/zbxdb/db.c:718: undefined reference to `mysql_insert_id' collect2: ld returned 1 exit status make[3]: *** [zabbix_server] Error 1 make[3]: Leaving directory `/usr/src/redhat/BUILD/zabbix-1.3.3/src/zabbix_server' make[2]: *** [all-recursive] Error 1 make[2]: Leaving directory `/usr/src/redhat/BUILD/zabbix-1.3.3/src/zabbix_server' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/usr/src/redhat/BUILD/zabbix-1.3.3/src' make: *** [all-recursive] Error 1
