Zabbix 1.3.3 RPMs Available
  • clahti
    • Jan 2007
    • 126
    [UPDATED 03/08/2007]
    Hello all:
    I have RPMs available for the latest 1.3.3 release for the following RedHat platforms:
    Fedora Core 6
    Compiled with current yum update as of 3/8/2007
    RedHat EL4/Centos 4.4
    RedHat EL3/Centos 3.8
    Compiled with current yum update as of 3/8/2007 AND upstream MySQL 4.1.20 from EL4. I have included the recompiled dependencies for php, mysql, and perl-DBD so that you can run the zabbix server on your EL3 box. Please note this has not been tested.
    You can find the Zabbix RPMs here:
    The contributed dependencies for EL3 are here:
    ChangeLog:
    -Fixed the /etc/init.d/zabbix server script to kill the pid if the server is stopped
    -Removed the --with-ldap parameter since this seems not to work anymore
    -Added --with-libcurl and the necessary dependencies
    -Added server install dependency for php-bcmath (fedora core 6 only, centos 4 has no separate php-bcmath rpm) since lots of people have trouble with initial installation and this is the culprit
    Thanks to Siegfried for hosting these
    NOTE: 1.3.2 RPMs for all platforms have been removed from the website due to storage constraints, email me if you need these.
    /Christian
  • marcele
    • Mar 2007
    ChangeLog:
    Added server install dependency for php-bcmath since lots of people have trouble with initial installation and this is the culprit
    [/QUOTE]
    Is there a php4 based rpm for this somewhere? .. all I can see is the one for php5 in the centos extras repos..
    • clahti
      • Jan 2007
      • 126
      hmmm...I run my server on Fedora Core 6 so I did not realize that RHEL4/Centos4 might not turn this on by default. I downloaded the src RPM for php-4.3.9-3.22.src.rpm and checked this out. It seems that bcmath is indeed enabled, so I am suspecting that the bcmath.so file is installed by default on RHEL4 and is not compiled into a separate RPM. I am recompiling the package to confirm this, and if so I will respin the zabbix RPMs to remove this dependency as a separate item. Stay tuned.
      • clahti
        • Jan 2007
        • 126
        ok, so it seems that bcmath is builtin to php4 on RHEL4 and CentOS4, so I will respin the zabbix RPMs, I need to do this anyway to add the dependency for libcurl
