make[3]: Leaving directory `/usr/src/RPM/SOURCES/zabbix-1.3.3/src/libs/zbxsys'
Making all in zbxdb
make[3]: Entering directory `/usr/src/RPM/SOURCES/zabbix-1.3.3/src/libs/zbxdb'
if gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/usr/include -g -O2 -MT libzbxdb_a-db.o -MD -MP -MF ".deps/libzbxdb_a-db.Tpo" -c -o libzbxdb_a-db.o `test -f 'db.c' || echo './'`db.c; \
then mv -f ".deps/libzbxdb_a-db.Tpo" ".deps/libzbxdb_a-db.Po"; else rm -f ".deps/libzbxdb_a-db.Tpo"; exit 1; fi
db.c: In function 'zbx_db_connect':
db.c:168: error: 'name' undeclared (first use in this function)
db.c:168: error: (Each undeclared identifier is reported only once
db.c:168: error: for each function it appears in.)
make[3]: *** [libzbxdb_a-db.o] Fehler 1
make[3]: Leaving directory `/usr/src/RPM/SOURCES/zabbix-1.3.3/src/libs/zbxdb'
make[2]: *** [all-recursive] Fehler 1
make[2]: Leaving directory `/usr/src/RPM/SOURCES/zabbix-1.3.3/src/libs'
make[1]: *** [all-recursive] Fehler 1
make[1]: Leaving directory `/usr/src/RPM/SOURCES/zabbix-1.3.3/src'
make: *** [all-recursive] Fehler 1
gcc-4.1.2
Making all in zbxdb
gcc-4.1.2
