1.3.3 web config (initial install)
  • riegersteve
    • Oct 2004
    • 68
    apache2/php5
    the web config keeps restarting and not savings the settings, i even populated the db manually but cant bypass the webconfig
    any advice ?
  • clahti
    • Jan 2007
    • 126
    this is a common problem, you probably need to flush your browser cookies, and/or you do not have the php-bcmath dependency present.
    Alexei - can we update the documentation to mention this very common problem? This happens mainly on recent Fedora Core releases, as php-bcmath was busted out into a separate RPM install. Earlier versions of RH included php-bcmath in the core php installation, I am not sure why they separated it subsequently...
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      1.3.3 installation wizard didn't check for presence of bcmath. It is fixed in pre 1.3.4.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • qbxk
        • Mar 2007
        bcmath is missing on gentoo too
        installing zabbix-server-1.1 on gentoo is yielding a bcmath problem as well
        looks like it was also missing gd, make sure if you havent that your USE variable contains bcmath, gd, and mysql when emerging php (which isn't a very quick rebuild... )
