I'm using Zabbix 1.3.3(beta) and when I setup a simple check for icmpping or icmppingsec all the zabbix server processes exit. Below is the log file showing that it dies on a sql query.
2828:20070315:115826 HOSTNAME [opennms.channeladvisor.com]
2828:20070315:115826 In do_ping()
2828:20070315:115826 Update IP [opennms.channeladvisor.com is alive (5.91 ms)]
2828:20070315:115826 Mseconds [5.910000]
2828:20070315:115826 IP [opennms.channeladvisor.com] alive [1]
2828:20070315:115826 In process_value([email protected])
2828:20070315:115826 In process_ip([opennms.channeladvisor.com])
2828:20070315:115826 End of process_ip([-1])
2828:20070315:115826 Executing query:select i.itemid,i.key_,h.host,h.port,i.delay,i.descriptio n,i.nextcheck,i.type,i.snmp_comm unity,i.snmp_oid,h.useip,h.ip,i.history,i.lastvalu e,i.prevvalue,i.hostid,h.status,i.value_type,h.err ors_from,i.snmp_port,i.delta ,i.prevorgvalue,i.lastclock,i.units,i.multiplier,i .snmpv3_securityname,i.snmpv3_securitylevel,i.snmp v3_authpassphrase,i.snmpv3_p rivpassphrase,i.formula,h.available,i.status,i.tra pper_hosts,i.logtimefmt,i.valuemapid,i.delay_flex, h.dns from hosts h, items i where h.status=0 and h.hostid=i.hostid and h.host='opennms.channeladvisor.com' and i.key_='icmpping' and i.status=0 and i.type=3 and configid>=100000000000000*0 and configid<=(100000000000000*0+99999999999999)
2828:20070315:115826 Query::select i.itemid,i.key_,h.host,h.port,i.delay,i.descriptio n,i.nextcheck,i.type,i.snmp_community,i.s nmp_oid,h.useip,h.ip,i.history,i.lastvalue,i.prevv alue,i.hostid,h.status,i.value_type,h.errors_from, i.snmp_port,i.delta,i.prevor gvalue,i.lastclock,i.units,i.multiplier,i.snmpv3_s ecurityname,i.snmpv3_securitylevel,i.snmpv3_authpa ssphrase,i.snmpv3_privpassph rase,i.formula,h.available,i.status,i.trapper_host s,i.logtimefmt,i.valuemapid,i.delay_flex,h.dns from hosts h, items i where h.s tatus=0 and h.hostid=i.hostid and h.host='opennms.channeladvisor.com' and i.key_='icmpping' and i.status=0 and i.type=3 and conf igid>=100000000000000*0 and configid<=(100000000000000*0+99999999999999)
2828:20070315:115826 Query failed:Unknown column 'configid' in 'where clause' [1054]
2816:20070315:115826 One child process died. Exiting ...
2816:20070315:115826 zbx_on_exit() called.
2818:20070315:115826 Got signal. Exiting ...
2827:20070315:115826 Got signal. Exiting ...
2840:20070315:115826 Got signal. Exiting ...
2831:20070315:115826 Got signal. Exiting ...
2826:20070315:115826 Got signal. Exiting ...
2848:20070315:115826 Got signal. Exiting ...
2835:20070315:115826 Got signal. Exiting ...
2817:20070315:115826 Got signal. Exiting ...
2825:20070315:115826 Got signal. Exiting ...
2836:20070315:115826 Got signal. Exiting ...
2819:20070315:115826 Got signal. Exiting ...
2847:20070315:115826 Got signal. Exiting ...
2838:20070315:115826 Got signal. Exiting ...
2820:20070315:115826 Got signal. Exiting ...
2846:20070315:115826 Got signal. Exiting ...
2824:20070315:115826 Got signal. Exiting ...
2842:20070315:115826 Got signal. Exiting ...
2821:20070315:115826 Got signal. Exiting ...
2845:20070315:115826 Got signal. Exiting ...
2823:20070315:115826 Got signal. Exiting ...
2822:20070315:115826 Got signal. Exiting ...
2816:20070315:115828 ZABBIX Server stopped
